You can pick from a 40mm or 60mm valve tube. These are great tubes. Around 70 grams.
http://www.cbike.com/michelin6packaircompultralighttubes700c.aspx
May give these a try. Need some spares anyhow. Thx.High Gear said:You can pick from a 40mm or 60mm valve tube. These are great tubes. Around 70 grams.
No worries, I have purchased a number of things from Cbikes including wheels and they have always delivered what I ordered without any drama.marktomin said:thank you, i placed an order. hopefully this is a good store as I've never ordered from them before.
Yes it is a bit much. But can you find six A1 tubes shipped to your house for $33?gearguywb said:Great price on the tubes but 11.00 shipping is a bit much.
Probably not, but if you are going to "save" by buying in bulk then IMHO there should be more of a savings vs heading down to the LBS and picking up one or two tubes at a time for 1.00-1.50 more.High Gear said:Yes it is a bit much. But can you find six A1 tubes shipped to your house for $33?
They are brass.MarvinK said:Anyone know if the valves are brass... or silver colored?
