1 - 3 of 3 Posts
Out of work goaltender
i'm considering these tires because they sound extremely durable and the roads i end up on seem way too cruddy for pro 2 races (even though they look so much cooler). my concern is that wherever i read descriptions for these tires they only mention it as a training tire and i'd like to do some racing with them. is this possibly due to them being heavier? or riding rougher? thanks.
If they are like the Carbons, they have a thicker rubber and are made to last longer. They have pretty good Crr though... as I recall about .005 vs ~.004 for the Pro2s and Corsa Cxs. They are better than Continental's best racing tires.
They should be a little bit heavier, but Crr is a much more important concern.
I'd use the Pro2s for racing unless your roads are really bad. Consider getting bigger tires and running reduced pressure (<100psi) if the roads are rough.
I have those, 700*23C size.
It is too early to tell but after about 300 km Krylions seem quite robust. I used to ride on Bonrager Race-X-Lite that were on my Madone (lasted about 5000km btw, 4 flats) and those had a number of small cuts and tiny emdedded objects after the same distance as I recall. They were soft, sticky but at expense of easy to cut/puncture. However, Krylions are definitely a harder and heavier rolling tyre compared to Race-X-Lite. I am going by my gut feel here. I bought them for fitness riding/training so for me a little slower is ok if I puncture less and if they last longer than 5000km. They were a bit tough to mount on my Race-X-Lite wheels. Their max recommended pressure, as stated on sidewall, is ~116psi. I ride on 100psi and that seems plenty for these tyres (I weigh 66-67kg plus add clothes).
But so far no regrets but early days yet.
Warning: I read that Carbons (and presumably Krylions too) are not good on wet roads. I use my Tacx trainer on wet days so I am not too fussed about it.
1 - 3 of 3 Posts
