Hey fella's. Just an update. Fiddled around with the set up yesterday. I bolted up the Bull horn bar and TT200 levers. I also reset the angle of the pads on the rear. The fronts were ok, but the back pads were a little out. So pads are now touching the rim with the front of the pad first, just slightly before the back does. Also, I haven't mentioned before. im using Swiss top black pads. So you would assume they would be a quality product that would provide good braking. Ok, the cables are not high end, but they are brand new, and im using the correct type. I had a different end on them before and had to file them to fit. But I have the exact cable required for the lever now. Not that it really matters, as I haven't noticed any difference from the old cable to the new.
Anyways, after the set up change, I took the bike out for another spin. Still not happy. Id say fractionally better, but not what I would like or expect. I wouldn't feel comfortable in an emergency stop, put it that way. If I operate both levers, the brakes work ok. But individually they just don't give me much confidence. The fronts pull up adequately, but the rears won't even lock up under maximum pressure. They will when fronts are applied together, but not when just the rear brake is applied. In comparison to my Surly Cross check with Canti's and Tektro drop levers and larger tyres and heavier wheel (Rohloff hub), it instantly locks up the wheel with minimal effort.
I then considered changing back to the Midge and drop levers, after having a good look at Refunds pics (thanks for the pics mate ! those bikes are real nice examples). So I had a better look at the Crane Creek drop levers that were originally on the bike with the normal drop bar. I noticed that the inner spring and a bush was missing from one of the levers ! I was pissed ! So that would explain the pivot coming loose all the time, and the small amount of play I noticed in the lever. It also rules out fitting them back on the bike with the Midge for now.
Refunds brake lever on the Midge do look odd though, they look nice but how do they feel for comfort and accessibility ? Do they provide quick access in an emergency stop ? Im asking because I had mine mounted a little lower down the bar. So I could have easier access to them.
So what do you's reckon ? Anything I can do to fine tune the Bull horn set up ? Can they be improved ?? Or should I go back to the Midge with the drop levers ? The Midge bar was my first choice though,and the braking was MUCH better with the drop levers. Answered my own question really haven't I ?
But, would still like to hear some tips or advice. As im not really an experienced bike mechanic, and still learning here.
Cheers
