1 - 20 of 23 Posts
Which cross frames are good candidates to be converted to monstercross? Looking for something that can handle 40s front & rear - either canti or disc.
Is not a clown car
New or used? Of course the Surly Cross check is the prime option. Voodoo has one. Masi has one coming out soon.
I carry Singular Peregrine's in my shop. They are disc specific, and can carry a tire up to 40c with fenders, or 2.1" if you want to go that big. I have mine set up with 2.1 Nano raptors and an Alfine hub. Not really racing material, but goes anywhere I point it. Which I like.
Is it a completely new bike or just a modified version of an existing bike? I like the Masi Special CX cross bike. It would nice to have a Special that could take big tires.
( ͡° ͜ʖ ͡°)
I never understood exactly what differentiated a "monstercross" bike from a 29'er MTB with drop bars.
Sorry for the threadjack, but wtf is monstercross and why couldn't you just pick out your favorite rigid MTB and slap drop bars on it?
For me, my cross bike has a 54 cm TT, whereas my 29er has a 60 cm TT. It makes a big difference on whether or not I can run drop bars with a normal stem.
Discussion Starter · #8 ·
unclefuzzy_ss said:
New or used?
Doesn't really matter - I'm looking for standard (non-custom) frames that are able to be converted to monstercross with simply a wheel/tire change.
Exactly - I'd like it to be able to do anything from a brisk road ride to a gravel grinder to a cx race to non-technical singletrack
Discussion Starter · #10 ·
For my needs, it's a cross bike that can handle WIDE tires, and maybe have disc tabs. Others will debate the finer points, but I think it boils down to it's more of a cross bike than a MTB.
It's all in the name. It's a monstercross not a monstermtb. The purists, if they can be called that, have pretty much decided it's a fat tire cyclocross bike not a rigid 29er.
Iohannes fac totum
Rawland has some good options. Lots of flexability with the frame, ESPECIALLY if you are open to 650b wheels in addition to 700c. Next year a 650b 40-45c Mini Moto should hit the market as well. The Drakkar runs up to 700-37c tires, but in 650b it runs all the way up to 2.3 fat MTB tires. Drap Bar specific. Very cool bike.
http://www.rawlandcycles.com
I have an '06 Redline Conquest pro and I have run 42s and there is still a little space between tires and stays. I have disc tabs on my frame and fork but 130mm spacing.
Discussion Starter · #15 ·
The Drakkar looks interesting - how hard would it be to swap between 700 and 650b set-ups? Is it as simple as changing wheels sets? Would give a lot of flexibility to swap between road, cross and mtb tires if all you had to do was change wheels to match the terrain & ride plans.
I have a tricross sport than easily accommodates a 29x1.8 up front and a 700x42 rear. The 29x1.8 in the rear just barely rubs the chainstay on one side. I could probably make it work by trimming the knobs.
Iohannes fac totum
With discs it would just be a simple wheel change.
Is not a clown car
In its simplest terms, its a bike with huge tires that is capable of trail riding, but is more suited to gravel and road use.
Another option, the forthcoming, overly long-named Gary Fisher Collection by Trek Erwin or Lane.
From what I've heard, room for 45mm tires with a bit of room. Added bonus (for some of us at least,) of sliding dropouts, and a bolted driveside dropout that should allow a belt drive.
Cyclist
I'm gonna do it with a Singular Gryphon frame...courtesy of Uncle Fuzz. More of a full on drop bar 29er as it has room for big meat. I'll do some crossing on it with appropriate tires though.
1 - 20 of 23 Posts
