1 - 6 of 6 Posts
Am going to be picking up the new ride next week :) Pinarello Galileo but don't fancy the MOst compact chaniset much :(
Am just checking to change it over to an Ultegra all I need is a BB and obviously a ultegra chainset??
Cheers
You can easily change it over to Ultegra. However, take into account that your rear gearing in combination with the bigger chain rings may not be suitable for your type of riding anymore. So, you may require a different cassette as well. Also, there's a chance that the chain might be 1 link too short. You'll also have to adjust the front derailleur height (including the clamp) to accommodate the larger ring, thereby exposing a possible mark in the frame finish of the previous clamp position (may not matter to you).
1 - 6 of 6 Posts
