Hi All,
I just got a flight deck with the 10 spd mounting kit and I'm having a problem with the magnet. The instructions say to put the magnet on the spoke, then slip on the steel ring and then the screw. Easy enough, but the screw bottoms out on the spoke before the ring seats down against the spoke, leaving the ring to rattle around loose. Do I just need to grind down the screw to make it shorter?
Thanks in advance!
Walt
Thanks in advance!
Walt
