There are top and bottom pull versions of certain MTB FDs, and some that can accommodate either cable approach. A top-pull specific FD will not reverse the shifting if pulled form the bottom though -- it won't work at all.krisdrum said:Aren't most mtn fds top pull and most road fds bottom pull? It will likely work, but won't shifting be reversed on the sti lever?
Are you asking if the difference between the stock 52 on an Ultegra triple and a 53 is similar between the difference between a 48T and a 53T?CleavesF said:Well can't you also argue most road FD were designed for 53T and 39T?
From my understanding MTB FD are supposed to work with the "trekking" cranks of 48T right?
Is 5 teeth really that big of a difference?
