1 - 2 of 2 Posts
My rear rim is bent on my easton circuit wheelset. I need to buy a new rim, what rim brands would be compatible with the spokes that come with Easton circuits? I cant seem to find any easton rims for sale, so would a regular mavic open pro rim do the trick?
I will need the LBS to relace the wheel, plus having to buy a new rim and maybe new spokes, would it be cheaper to just spend a few hundred bucks on a new or used wheel instead?
Last I checked there is a Curcuit rear wheel on Ebay right now.
Since Easton recently discontinued the Circuit, you may be able to get a replacement rim through them. Otherwise, the closest rim is probably a Kinlin 27mm.
I don't think an Open Pro would be a good match, as they are just a standard box rim, if I am correct. That will mostly negate any aero advantage you are getting with the Circuits.
1 - 2 of 2 Posts
