Pics & spec here.
Here's the spec on the bike -
Kish titanium frame. Straight gauge tubing.
Reynolds Ouzo Pro fork.
BWW wheels, two sets -
Carbon with 50mm Gigantex rims. CX-Ray 24/28.
Blackset Race. CX-Ray 24/28
Ultegra 6600SL (the dark grey stuff) -
- Crankset, compact. 50/39. Salsa inner ring.
- Shifters/brake levers.
- Derailers f&r.
- Brakes
Ultegra Cassette. 10spd.
Thomson stem (130mm), seatpost (30.9mm) and clamp (34.9mm)
PZ Racing CR6.3 bars.
Cane Creek 110 headset.
Chris King bottom bracket.
Vittoria Open Corsa Evo CX 25mm tires. Conti tubes.
Sram chain.
Speedplay Zero pedals.
King titanium cages.
San Marco Concor saddle. Vintage.
Fizik h/b tape.
Victory Circle Grafix name decal.
Weight 18.5lbs.
Here's the story on the finish -
Jim bead blasts the frame and then brushes it with 3M 7447 Scotchbrite (the maroon stuff). Originally I thought the frame was just blasted as it looked matte and I wanted to avoid matte blasted as it's not possible to get rid of scuffs without re-blasting. But Jim assured me that he went one step further than basic bead blasting - he brushes them out with the fine Scotchbrite which leaves what I'd describe as a perfect pearly finish - I can't detect any brushing marks at all. Ok, now I can in the bright sun. He assured me with this communication -
The main reason I do the finish this way is because it's easy to maintain. A blasted-only finish is not easy to maintain unless you own a blast cabinet.
I could save myself a lot of labor if I just did a blasted finish and sent them out like that. I call it brushed because I stand in front of the frames for a lot of hours every week wearing out scotchbrite pads. It's more subtle because the pads I use are very fine. It would save time to use coarser pads, but the result looks bad to my eye, and it's harder to blend if you need to do any work on it further down the road. Your typical blasted or wire/nylox brushed finishes are what I'd consider industrial finishes, done that way for efficiency. Mine is a hand finish. It's anything but efficient.
If you need to get rid of any scratches, fingerprints, etc, just get a maroon scotchbrite pad and buff it out, it'll take 5 seconds, You'll see what I mean if you try it. It blends VERY easily. Then squirt it with Armor All and you're done.
The finish is incredible, very subtle and impossible to do justice to with a photograph.
