1 - 5 of 5 Posts
So, I purchased this bike from a co-worker for $75. I plan to replace the tires, and tubes, along with the handlebar wrap, then use it as a commuter. It needs some cleaning, adjusting, and polishing, but I think I got a pretty good deal. I believe its an 86, PGN10.
Reynolds 531? Possibly English thread bb. If so very good score.
You didn't get a pretty good deal. You got an AMAZING deal. Thats a beautiful bike. Its amazing what a little TLC will do to an old bike. I would consider stripping the whole drive train down and cleaning everything. You'll be amazed at what builds up over 30 years. Plus you'll learn a bit about your bike and really have that connection to it. Other things you may want to consider replacing are your cables if they aren't new. At least lube them and check out to see if there is any cracking in the cable tubes. Congrats, you have a beautiful bike and a fun project to work on.
The tubing is Reynolds 501, and I am still unsure about the bottom bracket threading. I am planning to clean, and lube everything, including the cables. Thanks for the kind words, and I will continue to update as the project progresses.
Arrogant roadie.....
I can see from the Reynolds sticker that the 501 is flat, which means it's butted tubing only in the main triangle. Better models (such as the PX10) have full butted frames, on which the sticker has the numbers 501 on an angle.
1 - 5 of 5 Posts
