1 - 11 of 11 Posts
I have a set of Wellgo Look knock-offs that came on my bike. They have worked fine for me for two seasons now. The other day, my right pedal suddenly became very tough to get out of. My cleats are in great shape and I have made no adjustments to the pedal at all. Anyone know why it would get like this all of a sudden?
Are you sure your cleats are in great shape?
That would be the first thing I would suspect. You can also inspect the plastic clamp in the rear, maybe loosen up the tension and see if it moves ok.
However, my money is bet on the cleat just being worn enough to make it hard to unclip.
Adorable Furry Hombre
Also, IIRC Wellgos don't have a great rep to begin with
How are these Wellgo pedals overall? Are they ok or junk? I was under the impression that they come on the bike as sort of a "cheap filler" until you get real pedals. I never had a problem with them, so I never changed them.
I will try putting a new cleat on there and see if it fixes the problem!
They are ok
You pretty much get what you pay for, but I know several riders who have had them for years. I have an old pair on one of my kid's bikes. Work fine. Mostly they skimp on bearings, etc., so they are a low end pedal. However, if they work for you and you don't feel the jones for a new pair, why change?
I am too fickle and have to change pedals (and bikes, components, etc.) every so often. It's a sickness.
try this
I have Ultegra pedals/cleats and had a similar experience. This might help you.
Do you mostly clip/unclip using the same foot (i.e. mostly right foot, based on your question)?
if so and assuming your cleats are bi-directional then just swap over cleats left to right on your shoes and see if it helps.
In my case my left cleat had problems because I always clip/unclip with my left foot. So the left cleat was worn more than right. I swapped them over and the problem disappeared, ~1000 miles ago.
That's a great idea...I'll try that today, thanks!
Discussion Starter · #8 ·
Ok...I swapped the cleats on my shoes. I didn't put new ones on, but switched them from left to right. Same problem. I still have a very hard time unclipping from my right pedal. The left pedal, that now has the cleat from the right one unclips and clips perfectly. I have looked over the pedal meticulously and found nothing obvious. I lubed everything as best I could...no luck. Could it just be that Wellgo's aren't designed to last for 3 seasons?
Island Hopping cyclist
Clean the releasing hinge on the pedal. Any debris in there will jam it up. I had a similar problem with Look pedals after a stop on loose sand. I clipped back in, rode off, but couldn't unclip once I tried to stop again.
Resident Curmudgeon
The only time(s) I've had a problem like this is when the cleats were'nt tight enough on my shoes. The red Looks have some built-in float, so if they work loose, it isn't always obvious. If they're just a little loose, they'll rotate on the sole of your shoe, making uncliping very difficult. Make sure the cleats are very tight.
"Cypress Gardens" Fl.
Not quite........
I would'nt call Wellgo pedals junk. They might not be the same level as upper end "Look", but they're still pretty good. In fact, just recently I re-installed my old Wellgo pedals because the cleats wore out on my Looks. They're just as silky smooth now as they were when I took them off. I have about 4000 miles on them too.
1 - 11 of 11 Posts
