After reading the very heated clinchers vs. tubulars debate with a sub debate on rotational weight perceptions and realities I came up with a couple of my own ideas. I am very good at math but I am not a physics major, so I would welcome any comments.
Wouldn't riders who do not spin very well (like myself) benefit more from a reduced rotational weight due to the micro acceleration differences derived from the alternating 2 major pedal strokes of your revolution? In essense having two accelerating and two decelerating periods with every revolution of your crank. Although your actual velocity might not vary more than a few tenths or hundreths wouldn't more than 1/2 of your pedal stroke be spent on true acceleration.
I have wrapped my head around the idea that at a "constant" speed, rotational weight makes very minimal difference, but who is pedalling at a truely constant speed without acceleration? As far as "engine" smoothness goes, I would think a dual piston engine (insert rider here) would not be a very constant propelling force. Combine that with the increased inertia? required to complete a revolution on a much less smooth uphill climb, where many riders have to get out of the saddle and 1 2 mash their way to the crest. I wonder how long it would take to develop a good smooth spin technique while out of the saddle.
edited to add.....I would think the periods of acceleration and deceleration climbing a hill would be much more pronounced with less (shorter) "maintainence" energy. For instance... and this is anything but scentific....
Let's say you are pedalling a slow (but mathmatically easy) cadence of 60 with each full revolution of your crank taking 1 full second.
Say the downstoke of your drive side crank arm takes 4/10 a second as does the downstroke of your non-drive side crank arm.
The "lull" or transitional period where the stroke is not as smooth (which I am sure would not be near as pronounced with a pro rider) is a tenth of a second on each side.
So here we are with 8/10 of a second spent on downstrokes of each piston and 2/10 of a second on the "transitional" time.
Assume the 3 of the 4 tenths on each downstroke is spent accelerating and 1 of the 4 tenths on the downstroke and the tenth of transitional time is spent decelerating. (there would be two much smaller fractions of a second where there would be neither acceleration or deceleration)
Wouldn't that mean we have spent 60% of our revolution as acceleration and 40% as deceleration? Surely at least on a micro level?
Does this then mean that rotational weight could be more important than formulas that use "constant" speed prove?
