The best solvent for most tubular glues is toluene (aka toluol) or xylene (aka xylol). These are aromatic solvents and are far more effective than somethink like acetone. If you go to your local paint store and read some labels on paint thinners you can look for "aromatic solvents" which is what classically toluene is.Velonews article
Technical FAQ: Tips for removing tubular glue
+1 on using Naptha. I pour a little in a pan and use a piece of "green scrubie" to rub on the rim. I finish with a paper towel dampened with naptha.I use VM&P Naphtha based on this letter. It works better than other stuff, but is still a chore.
Technical FAQ: End-of-season rim and tire care
Again, get some aromatic solvent (toluene or xylene), soak a bit into a rag, and rub the glue right off. These will not damage the rim - you're not soaking the plastic in the solvent.Sorry for the late reply, internet was out for like a week.
Anyways, during this time I bought 100% acetone. Let me tell you, it doesn't really work that well.
Goo Gone kinda works, but I'm either going to soak it like in the Zinn article, or try a heatgun at this point.
The glue from the previous owner has been contaminated into a layer about 2-3mm thick. It's gonna take a long time...
Unfortunately for me, both these are banned in Calif. It varies by "air pollution control district" (I think), so obscure rural regions of the state are possibly exempted.The best solvent for most tubular glues is toluene (aka toluol) or xylene (aka xylol)..
Have you looked on the shelves of your local paint store? You might find a paint thinner that contains aromatic solvents. Obviously I've never done that in CA but it's worth a look.Unfortunately for me, both these are banned in Calif. It varies by "air pollution control district" (I think), so obscure rural regions of the state are possibly exempted.
Nearly all the "good" formulations of auto body paints are banned in Calif, too.
Next time I find myself in Nevada, I'm going to stock up on xylenes, toluene, & naphtha!
In So Cal, the paint/hardware stores only sell minerals spirits, acetone, alcohol, and lacquer thinner.Have you looked on the shelves of your local paint store? You might find a paint thinner that contains aromatic solvents. Obviously I've never done that in CA but it's worth a look.
That might work - at least it's worth a try. Naptha has a very broad definition and may contain enough aromatics to make it work. Clearly methanol and acetone won't do much good.In So Cal, the paint/hardware stores only sell minerals spirits, acetone, alcohol, and lacquer thinner.
A typical lacquer thinner is made of:
Methanol 15-40%, Toluene 1-5%, Acetone 10-30 %, naphtha 15-40%, +misc
