I currently ride an old Peugeot w/ 27" x 1 1/4" tires around the City and I've gotten fed up with the jarring I take on the numerous potholes, mainly on my hands. I wear padded gloves and use cork wraps.
I'm going to get a new bike and have the choice of getting the Sport Tour which has 700 x 32 with no front shock http://www.llbean.com/webapp/wcs/st...langId=-1&categoryId=54952&sc1=Search&feat=sr
or
the K2 Alturas 2.0 Fitness Bike with 700 x 35w tires and a front shock. http://www.llbean.com/webapp/wcs/st...langId=-1&categoryId=54957&sc1=Search&feat=sr
or
http://www.k2bikes.com/index.php?br...NE&model=Alturas 2.0&2007=false&show=Expanded
Both have a shock seatpost.
Both have cushioned grips.
The Alturas has a coil spring seat.
Sport Tour might have better components...not sure.
I want to give up as little performance as possible while making rides over the bone rattling potholes tolerable. Do you think the 700 x 32 tires on the Sport Tour will handle the pot holes significantly better than the 27 x 1 1/4", or would the difference be small and therefore ought I go with the 700 x 35 tires and front shocked Alturas?
Other differences (which are not mentioned on website):
Sport Tour 27lbs, Alturas 29lbs. (I weigh 270 and could stand to drop 70.)
Sport Tour 7000 series aluminum forks.
My current Peugeot has a steel frame. Is it true that steel absorb shocks better than aluminum? Therefore, would I be getting a harsher ride from the frame and taking a step backwards in that area. If so, would the benefit of a slightly wider tire be offset, neccesitating the much wider tire and shock/spring seat?
or
or
