1 - 3 of 3 Posts
cross post from wrenching forum
I have a 1970's cross frame which I use for fixed commuting
the frame doesn't take modern cantilever brakes very well - I think originally it took MAFAC cantis which are virtually impossible to get hold of
the front fork has 6cm clearance at the cantilever stud - the rear frame/seatstays have 7.5 cm clearance at the cantilever stud
any suggestions on where I could find some brakes that fit - have heard that Spooky and Pauls may work but don't wanna spend the cash without knowing they'll fit the frame
thanks!
· "It's alive!"
thanks!
I'd probably give up and mount some long reach centerpulls or sidepulls - if possible. You could cut the canti bosses off or leave them on for that urban assault vehicle look.
- FBB
may do - I emailed Pauls (and others) the consensus seems to be that this is a common problem with older bikes - everyone says that minimum space required is 7.5cm (exactly the space in back) - as I only have 6cm in the front they suggest I have the studs/bosses moved
1 - 3 of 3 Posts
