1 - 16 of 16 Posts
Spectacular, they really did well with the blue frames this year. If I may? What did your LBS charge you for a built down Onix frame?
It is a beautiful bike, I was thinking about getting one for a training setup but only if I could get a frame set through the distributor like this, built it with my own spec. More of a fan of the Black/Red/White edition but with so much of that in the market the blue seems fresh.
Twins! Love the bike.
right around 17Lbs at LBS (how accurate, who knows)- blast to ride regardless
* Shimano Ultegra 6700 Groupset (exception of the crank- Ultegra SL) - upgraded in steps from 105's, bought the crank first and then the 2010 Ultegra's came out.
* Ritchey stem and Carbon Seat post
* 2010 Mavic Ksyrium SL's
* Fizik Antares seat
* 3T Ergonova handlebars
* Vredestein Fortezza's
here's a pic
Wow, looks great in the blue color and 17lbs is great.
I'm going to switch the stock 60tpi Rubino tires which I actually like to Diamante Pros and that should get mine to just under 19lbs. Don't think I would shave very much weight at all by switching to a carbon stem over the stock one. When I get the dough I may swap out the Shimano RS20 wheelset to Easton EA90 SL's and that should get me down to the high 17lb range.
Beautiful bike!
I have to agree, the bike is blast to ride. Here in San Francisco/Marin, the setup provides a very fast, stable, nimble ride through the hills/rollers...makes me envy how a well setup Orca would be (never taken one out on a comparable ride, but am dying to try).
Interesting comparison to see the visual differences in angle and dimensions between Ultegra 6700 & Ulterga SL's (shifter angle, rear derailer, etc).
In any event, your bike looks fantastic!
IMHO, nothing weak about that spec. The Rubino tires are really good, I'm switching mine out once they are wore out to a lighter tire just to shave some weight.
The Zeus brakes are the only question mark to me on this spec. Not saying they are bad, I just have no knowledge about these. The brakes are probably just fine, Orbea doesn't spec there bikes with sub-par stuff at all.
My nephew put one of these on layaway after he saw mine.
Like the Vittoria Rubino that came with my TDF... I will try the Vittoria Rubino Pro's next.
I really like the regular Rubinos that came on my bike too, so far 800 miles with only one flat, have been caught out in the rain twice and grip wasn't a issue. I'll try Diamonte Pros next and if I have any problems with those the new version Rubino Pros would be my next, both of the latter are way lighter than what came on the bike.
1 - 16 of 16 Posts
