I have been running campy 9 speed ergo shifters with shimano 9 speed cassette for a few years with only the occassional mis-shift. I just bought a new set of wheels (velocity aeroheads, white industries hubs) with campy hub body. I decided to convert everything to campy and figured it would shift perfectly.
I put new chainrings (FSA), chain (campy c9), and campy 12-26 cassette on. Previously with the shimano hub body I was running 12-23, but on canecreek rims. I put it all together and I can't seem to get smooth driveline motion on the 39x26, but it's pretty good on the 23 cog. When I back pedal, the chain gets snagged on the 26 too. Do I need to add a link to the chain to lengthen it for the 26 gear? I also put a couple spacers in between the hub body and cassette. This seems to have helped some, but the chain is almost touching the chainstay in the 53-12. The only other thing I can think of is the derailleur, which is also campy chorus 9 speed. I believe it is a short cage. Brandford bike says this deraillleur will work up to a 26, so I don't think that is the problem.
Sorry for the ramble, but I am heading to colorado next wknd, and I will be needing the 39-26 a lot. Thanks.
