1 - 11 of 11 Posts
Not likely
The question of "if" there will be a DA triple must remain open, as Shimano can change their plans at any time and do this. However, "when" there will be a DA triple can certainly be answered "not any time soon." IIRC Shimano said "no DA triple" so until they change their mind . . .
Rumors only...
But I've heard, mostly around the rec.bicycles.tech, that there won't be a DA triple. At least not until 2005 Ultegra comes out in 10 spd, and with a triple. Even then I hear it's questionable when a DA triple comes out.
Go Kart Motzart said:
Anyone have an idea if Shimano will produce a triple for the new Dura Ace?
Why do people want a triple? If you run a double and a 12-27 cassette you are only a couple of gear inches away from the triple range. The result is only one or two gears difference, plus better shifting up front with the double chainrings.
Not everyone is a racer...
Not everyone has racing fitness and some of us live in places with steep grades (15%+). When I first started riding I actually ran a triple with a 12-27 and I needed every gear. Now I get up the same hills in a 39X23, but I'm a heck of alot lighter and in alot better shape.
Now take a ageing club rider who has the cash for a $7000 bike. Last year that bike might have had a DA 9 triple... Whats it going to have this year?
Tourist
Try to do long rides....
the triple is nice even if you're in racing fitness when you have steep climbs at mile 190...
Pierre
ever ridden a mountain climb???
Try a 10-15 mile mountain climb starting at 6000 ft altitiude and you might change your mind. Although a 27T cog certainly helps, a 30T chainring often provides THREE additonal lower gears. With the wide-spaced 12-27, only the 30/24 and 30/27 are lower than the 39/27. The 30/27 is equivalant to a 39/35, which is a LOT lower than a 39/27.
The triple also permits the use of a higher cadence, around 80 rpm instead of 60.
HaHa
Tell it to Roberto Heras.
MichaelC said:
If I want to switch my 11-23 Dura Ace 7800 cassette to 12-27, would I have to replace anything else in the drivetrain?
The cassette lock ring for the 11 cog is specific. If you buy a new Shimano 12-27 cassette it should come with a new lock ring. You won't need to replace anything else, but check the chain length to make sure it's long enough to handle the big ring to big cog combination just in case you accidentally cross chain. You don't want the rear derailleur to go all of the way to its forward limit when you shift to the 27.
~Al
1 - 11 of 11 Posts
