1 - 8 of 8 Posts
I just placed an order for a pair of wheels with center-lock (White Industries) quick-release hubs. Currently I am using 6-bolt hubs with Shimano 160 mm diameter discs on my current wheels.
Is this an appropriate disc to get?
Shimano RT99 XTR Ice-Tech Center Lock Rotor 160mm
Does this come with a lock-ring, or do I buy that separately? If the latter, the only one I have found says "15/20mm thru-axle only" and doesn't have splines, so I assume this one I don't want.
Thanks, but also, the last line (which I now moved above the image):
"Does this come with a lock-ring, or do I buy that separately? If the latter, the only one I have found says "15/20mm thru-axle only" and doesn't have splines, so I assume this one I don't want."
Every shimano CL disk I have purchased (easily 10 of them) has come with an internal splined lock ring. The internal splined lock rings only work on 12mm rear TA's or QR hubs. They do not work on 15mm TA. For 15mm TA you need the external splined lock rings that you tighten with a bottom bracket tool.
The external ones work with any axel configuration however. I wish all the discs came with the external version.
Perfect. Thanks. That is exactly what I needed to know.
You can buy the external splined ones for about $7.
Sorry, thought I'd replied earlier but somehow I bungled it. Ergott's got it. Because the CLD front hub's design only takes externally splined lock rings (it takes literally 3 seconds to switch from 15mm to QR and back with no diminution or compromise of function - it's AWESOME) they supply the front lock ring.
Fat & Single
Here you go, the internal lockring comes with the centrelock discs. I have several sets of the Shimano Freeza rotors, including 140's on my roadie. This needs a cassette lockring tool to loosen/tighten.
The external lockring, this is needed to clear a 15mm/20mm thru axle, tightened/loosened with a BB spanner.
You would think that maybe Shimano should include a external ring with their XTR group rings... as its a MTB and likely to be 15mm thru. Then sell the Freezas for Road/CX with the internal for 12mm thru.
1 - 8 of 8 Posts
