Picked up a gravel bike and just getting things set up. My rear tire is losing air, albeit fairly slowly. I do not see any sealant goo coming out. Should I ride it and hope the sealant kicks in, add more sealant, other?
I pumped it up to 60 psi this am. Its about 10psi now. I will try the water methodYup, find the source of the leak first.
How slow is 'fairly slowly?
Some tubeless tires inherently leak. Which will seal up after some rides with sealant.
But if it's the tape or valve core you want to get that straightened out. Those may seal up from sealant too but I'd want them fixed.
You can also submerge the wheel in a bucket (or tub) of water. Even the smallest of leaks will stream air bubbles and tell you where it's leaking.
That's the best method. I found pinhole leaks through the sidewalls on some of my tires. Orienting the tire so the sealant puddle is over the leak soon sealed it. It could also be the rim tape. Leakage at the spoke nipples or even the valve stem indicate rim tape problems. I've even had valve cores leak requiring replacement or cleaning of the valve core.I pumped it up to 60 psi this am. Its about 10psi now. I will try the water method
Just tried the water plan. Went slowly around the tire twice including the valve. Saw no bubbles. Stumped. Maybe the sealant finally kicked in??That's the best method. I found pinhole leaks through the sidewalls on some of my tires. Orienting the tire so the sealant puddle is over the leak soon sealed it. It could also be the rim tape. Leakage at the spoke nipples or even the valve stem indicate rim tape problems. I've even had valve cores leak requiring replacement or cleaning of the valve core.
That could be. Especially if the bike sat without being ridden for a long time.Just tried the water plan. Went slowly around the tire twice including the valve. Saw no bubbles. Stumped. Maybe the sealant finally kicked in??
Thanks all for the advice. I am going to do a short shakedown ride and see what happens. If that doesn't work I may try adding some more sealantGo ride the bike, spread the sealant around.
I have the same issue and did the same thing about 12 hours ago today, with the same result, i.e., no trace of the leak. But the tire this evening is more squishy that it was this morning.Just tried the water plan. Went slowly around the tire twice including the valve. Saw no bubbles. Stumped. Maybe the sealant finally kicked in??
I did not expect tubeless to be such a PITA. After this experience I cannot see going tubeless for a road bikeI have the same issue and did the same thing about 12 hours ago today, with the same result, i.e., no trace of the leak. But the tire this evening is more squishy that it was this morning.
I put on a different wheel-set for a ride this evening. It seems to have no trouble holding air, but I noticed a bubble of sealant on the sidewall. Yet the tire felt fine before, during and after the ride. (The seepage stopped almost immediately, but WTF?).
Maybe I should try inner tubes.
My wife has tubeless tires on her road bike. I find them to be a PITA. When she needs new tires, I have to pay the LBS to mount them cause I can't get them off and on. The mechanic there struggles with them for 20 minutes a tire. And he does this for a living. I get relatively few flats and can fix one in minutes. I just don't see any benefit on a road bike unless you ride on glass shard strewn roads.I did not expect tubeless to be such a PITA. After this experience I cannot see going tubeless for a road bike
