I've decided to buy some new clincher road wheels in the $500 range. I'm looking for a pair to train and race on and also with sealed hubs for reduced maintenance. Recommendations? I should also mention I am on the heavy side (190 lbs).
if you have shimano or campy.Wiaruz said:I've decided to buy some new clincher road wheels in the $500 range. I'm looking for a pair to train and race on and also with sealed hubs for reduced maintenance. Recommendations? I should also mention I am on the heavy side (190 lbs).
Not a "sealed" cartridge bearing. Personally I like them better. I have more problems with my wheels that have cartridge bearings. The Protons use a Chorus based hub with the adjustable type bearings.You might want to get something else if you did not like that style of bearings.Wiaruz said:How do you find the campag hubs? I have not been pleased with my current Chorus ones. Even when re-packed the cones never run nice and sliky. I think I want to try some sealed units.
You should understand that cartridge bearings are not the only "sealed" bearings out there. You can seal a beaing system with labyrinth seals, which is what Campy does. You may find that a Campy hub resists water and dirt penetration just as well as many cartridge bearing hubs. To your request, a good builder can put together an excellent set of wheels for less than your price point based on Record or Chorus hubs, Velocity Aerohead/Aerohead OC, MAVIC OP, or DT rims and 15/16 spokes that will serve you well and meet your targets.Wiaruz said:and also with sealed hubs for reduced maintenance.
Not all cartridge bearing hubs are sealed in the sense that they actually do a good job of keeping water out. My Bianchi Pista has a set of wheels with generic Bianchi hubs with cartridge bearings and no supplementary seals. The bearings are visible from the outside of the hub. I disassemble the hubs every so often and peel off the bearing seal with a razor blade to pump out the dirty grease. A set of mountain wheels I own with Shimano XT hubs haven't been overhauled since I got them 4 years ago (ridden through lots of nasty mud and such). The labyrinth seals on Shimano's higher-end hubs work pretty well.Kerry Irons said:You should understand that cartridge bearings are not the only "sealed" bearings out there. You can seal a beaing system with labyrinth seals, which is what Campy does. You may find that a Campy hub resists water and dirt penetration just as well as many cartridge bearing hubs. To your request, a good builder can put together an excellent set of wheels for less than your price point based on Record or Chorus hubs, Velocity Aerohead/Aerohead OC, MAVIC OP, or DT rims and 15/16 spokes that will serve you well and meet your targets.
Ligero Wheels or Odds and Endos. Call, discuss, get wheels, be happy. If you have a local wheelbuilder you trust that's even better. If you want cartridge bearings you could pick the new White Industries or DT240 hubs.Wiaruz said:I've decided to buy some new clincher road wheels in the $500 range. I'm looking for a pair to train and race on and also with sealed hubs for reduced maintenance. Recommendations? I should also mention I am on the heavy side (190 lbs).
