Jimi_Lee said:
I was told by the LBS that the old BB lockrings have a different pitch thread then the track cogs and will mangle the threads. Is this true?
James
Track cogs, freewheels, and english BB lockrings are all threaded at 1.37 x 24tpi, right-hand thread. So, a BB lockring will thread on there fine, and help to hold just like two nuts on a bolt - not great, but better than nothing.
The confusion comes in because track
hubs have an additional threading for a lockring in addition to the cog, and that is threaded differently, at 1.29 x 24tpi left-handed. As was mentioned, that really locks things on, because if the cog tries to unscrew, it also tries to screw the lockring on tighter. But, that's a hub you don't have.
I do
not suggest the following:
I ride (with both brakes) on a converted (respaced and redished) wheel without either a lockring or locktite. I tightened it on very well with a chain whip and am running a fairly tall gear, so I don't have the strength in my legs to unscrew it, and usually brake rather than resist, which I reserve for minor speed-control. Following some of the discussions here, I loosened it manually and tried a spin-off under controlled conditions. I found:
1) It's fairly obvious when a cog breaks free and begins to unscrew.
2) It takes (for my rig) five full wheel revolutions for the cog to unscrew. That's a surprising amount of distance and time to get your legs going the right direction, or to stop properly (obviously, this is only for a brake-equipped bike.)
3) On a track hub, there's a concern that the cog will unscrew and jam against the dropout, causing an immediate lock-up of the rear wheel. On a converted hub, there's much more space available, so it's less likely to be a problem, especially if it's a seven-speed conversion. In the event of a full unscrewing, there would be loose parts rumbling around that could cause trouble, but the threat isn't as great as with a track hub. With my setup and manipulating things in every imaginable way on the workstand, I couldn't find a truly dangerous scenario, though could see where other setups could have problems, and there was some risk of minor damage.
4) The real source of danger is when using a fixed/free track hub with a track cog instead of a freewheel threaded on thee free side. There, the space to the dropout is very small, and there's no facility for a lockring of either type. That is the real 'suicide' setup, and the wisely safe have applied those lessons to converted hubs as well.
When I went to my LBS looking for a BB lockring for the same reason, I was told the same thing you were. I went out to the car, got the wheel, and threaded it onto the hub. I handed it back, and use another shop now.
The welding thing doesn't sound great to me. I have aluminum hubs and steel cogs, so it's impossible anyway. And if I didn't like the gearing I guessed at the first time, or simply wanted to experiment...
Like I said, I don't recommend doing what I do. There's every possibility that I'm as lucky as I am stupid.
