hello
just bought a used roubaix 2011 comp ultegra triple (8r carbon sl2) - weighs about 20 lbs (with pedals and speedometer). Even removing pedals it weighs about 20 lbs.
i noticed it weighed more than a roubaix comp compact 2013 which appears to be its closest equivalent 8r carbon frame. The comp was a bit over 18 lbs.
in fact, my 2011 weighed about the same as a roubaix elite compact 2013 -- and the Elite has all shimano 105 components, whereas the roubaix 2011 has all ultegra. (!!!)
Could the frame weights really be that different?
Specs are below:
2011 Roubaix Comp Ultegra Triple
FRAME Specialized FACT 8r carbon, FACT IS construction, compact race design w/ Zertz inserts, 1-1/8" to 1-3/8" headtube, threaded BB
FORK Specialized FACT carbon full monocoque w/ Zertz inserts
HEADSET 1-1/8" upper and 1-3/8" lower Cr-Mo cartridge bearings w/ 20mm cone spacer and 20mm of spacers
STEM Specialized Comp-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clamp
HANDLEBARS Specialized Expert shallow drop, 2014 alloy
TAPE Specialized S-Wrap w/ 2.5 gel pads
FRONT BRAKE Shimano Ultegra
REAR BRAKE Shimano Ultegra
BRAKE LEVERS Shimano Ultegra STI, flight deck compatible
FRONT DERAILLEUR Shimano Ultegra
REAR DERAILLEUR Shimano Ultegra
SHIFT LEVERS Shimano Ultegra STI, flight deck compatible
CASSETTE Shimano 105, 10-speed, 11-28t
CHAIN Shimano Ultegra
CRANKSET Shimano Ultegra
CHAINRINGS 52 x 39 x 30T
BOTTOM BRACKET With crankset
PEDALS Black cage, body & toe clips w/ strap
FRONT WHEEL Fulcrum Racing 6
REAR WHEEL Fulcrum Racing 6
FRONT TIRE Specialized All Condition, 700x23c, wire bead, 60TPI, w/ Flak Jacket protection
REAR TIRE Specialized All Condition, 700x23c, wire bead, 60TPI, w/ Flak Jacket protection
INNER TUBES Standard presta valve
SADDLEBody Geometry Avatar Comp w/ hollow Cr-Mo rails
SEATPOST Specialized Pro Carbon Pave w/ Zerts inserts, 27.2mm
SEAT BINDER Forged alloy, 32.6mm
NOTES Carbon chain stay protector, derailleur hanger, clear coat, owners manual
2013 Roubaix Comp Compact
FRAME Specialized FACT 8r carbon, FACT TM construction, 1-1/8" to 1-3/8" HT, compact race design, Zertz, internal rear brake cable, threaded BB
FORK Specialized Roubaix, FACT carbon, full monocoque, Zertz
HEADSET 1-1/8" upper and 1-3/8" lower Cr-Mo cartridge bearings, w/ 20mm cone spacer and 20mm of spacers
STEM Specialized Comp-Set 6061 alloy, cone head bolt, 12-degree, 4-degree shim, 31.8mm
HANDLEBARS Specialized Comp, alloy, shallow drop
TAPESpecialized Roubaix tape w/ 2.5 gel pads
BRAKE LEVERS
FRONT DERAILLEUR Shimano 105
CHAIN Shimano Tiagra 10-speed
CRANKSET Shimano Ultegra compact
CHAINRINGS 50/34
BOTTOM BRACKET
PEDALS Nylon flat test ride, loose ball, w/ reflectors
FRONT WHEEL DT Axis 3.0
REAR WHEEL DT Axis 3.0
FRONT TIRE Specialized Espoir Elite, double BlackBelt, 60TPI, aramid bead, 700x25c
REAR TIRE Specialized Espoir Elite, double BlackBelt, 60TPI, aramid bead, 700x25c
INNER TUBES Lightweight, presta
SADDLE Body Geometry Toupé RBX Comp, hollow Cr-Mo rails, 143mm
SEATPOST Specialized Comp, FACT carbon, 27.2mm
NOTES Carbon chainstay protector, derailleur hanger, clear coat, owners manual
2013 Roubaix Elite Compact
FRAMESpecialized FACT 8r carbon, FACT TM construction,1-1/8" to 1-3/8" HT, compact race design, Zertz, internal rear brake cable, threaded BB
REAR SHOCK
FORKSpecialized Roubaix, FACT carbon, full monocoque, Zertz
HEADSET1-1/8" upper and 1-3/8" lower Cr-Mo cartridge bearings, w/ 20mm cone spacer and 20mm of spacers
STEMSpecialized Comp-Set 6061 alloy, cone head bolt, 12-degree, 4-degree shim, 31.8mm
HANDLEBARSSpecialized Comp, alloy, shallow drop
FRONT BRAKEShimano 105
REAR BRAKEShimano 105
BRAKE LEVERS
FRONT DERAILLEURShimano 105
REAR DERAILLEURShimano 105
SHIFT LEVERSShimano 105 STI
CASSETTE Shimano Tiagra, 10-speed, 11-28
CHAINShimano Tiagra 10-speed
CRANKSETShimano 105 compact
CHAINRINGS50/34
BOTTOM BRACKET
PEDALSNylon flat test ride, loose ball, w/ reflectors
FRONT WHEELDT Axis 2.0
REAR WHEELDT Axis 2.0
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRESpecialized Espoir Elite, double BlackBelt, 60TPI, aramid bead, 700x25c
REAR TIRESpecialized Espoir Elite, double BlackBelt, 60TPI, aramid bead, 700x25c
INNER TUBESLightweight, presta
SADDLEBody Geometry Toupé RBX Sport, 143mm
SEATPOSTSpecialized Comp, FACT carbon, 27.2mm
SEAT BINDERForged alloy, 32.6mm
NOTESCarbon chainstay protector, derailleur hanger, clear coat, owners manual
Thanks for any insights
GaiusG
Specs are below:
BRAKE LEVERS
CHAINRINGS 50/34
BOTTOM BRACKET
REAR SHOCK
BRAKE LEVERS
CHAINRINGS50/34
BOTTOM BRACKET
RIMS
FRONT HUB
REAR HUB
SPOKES
GaiusG
