So I have a 2012 Noah on it's way. I have a pretty tight timeline for the build, so I am trying to head issues off before I start. It is coming from Competitive Cyclist, but I forgot to ask if they include a compression plug for the steerer tube, or the toss in a star nut. I am not a fan of the star nuts in carbon forks at all and have seen the compression plugs at Universal cycles so I will order one if it isn't standard. I will be running my Ultra Torque cranks in the frame, so I have a 68x42 campy cups inbound from the LBS. All the research I saw suggested that was the correct size for UT cranks. That is all I can think of for now but I am sure I will be posting more questions as they arise.
Edit: So I found on the Ridley website that it calls for 68x46 for the 2013. Guessing I need the same for my bike...damn.
Also, can't get a clean look at the installation of the rear brake cable. Is there cable stops or does it run a solid cable housing inside the frame?
