S36R stands for Symmetric, 36mm, Rim Brake.
S36R is a quick way of saying symmetric 36mm rim brake wheel (click to enlarge).​
While Nox made its name producing rims for the mountain bike market, the brand has recently branched out into the road segment. Its new carbon clincher rims are built specifically for competitive road racing.
The S36R is tubeless compatible. Just add a layer of tubeless tape to ditch the tubes.
The S36R is tubeless compatible. Just add a layer of tubeless tape to ditch the tubes (click to enlarge).​
Like its mountain bike product line, these new carbon clinchers utilize a wide rim profile for reduced rolling resistance and are tubeless compatible. Key metrics include 28mm outer diameter and 20.5mm internal diameter. That's paired with a 36mm deep "tapered parabolic shape" that Nox claims offers the best combination between aerodynamics and crosswind performance.
The friction layer of the brake track is an integral part of the rim and will not wear off like some coatings.
The friction layer of the brake track is an integral part of the rim and will not wear off like some other wheel coatings (click to enlarge).​
The brake track uses a 3k woven composite fabric that has been molded with friction additives that won't wear over time - and will stand up to extreme heat.
Prices for a complete wheelset start at $1,428, but vary depending on hub and spoke choice.
Prices for a complete wheelset start at $1428 depending on hub and spoke choice (click to enlarge).​
The rims will be available in 20, 24, and 28-hole variations and are shipped with either white or black decals. Custom color-matched decals and other drill counts are available upon request. Rim weight is approximately 410 grams and are available for $479. Or you can have a custom wheelset built to order through the Nox website. All wheelsets are built by hand at company HQ in Knoxville, Tennessee. Turnaround time is 1-2 weeks.
For more check out www.noxcomposites.com.
