since you're a celeste junky....
and i think dave mentioned the ENO hub.....
2003 eros frame, converted with an ENO. picked up the frame a bit ago on e-bay for pretty decent money. the wheel was on my old alu road frame, but i really wanted to go back to a steel frame. if youv'e got one of your frames that you love, all you'd need is to get the wheel built. got this wheel built for $215 from larry from mtn high cyclery.
velocity aerohead rim, 15-16 db spokes, alloy nipples. i've run a couple gear ratios so far with it. dead simple idea' one of thos "doh! why didn't i think of that....." granted, it's not a new idea, but it's the only one readily available. no slipping, and you get to use the frame you know already. works great! i suppose if you had a frame with some funky stay length, you may have trouble getting the gear you want, but i've not had a problem with the wheel on two frames now.
