1 - 9 of 9 Posts
I put a tubeless ready tire on a tubeless ready wheel, but I used a tube. I did this a couple of days ago. It slowly loses pressure from 50 psi to 30 over 24 hours. this has happened twice now. Is there just a leak in the tube? Maybe. But I am thinking that the tire may be sealing well enough against the rim, so that air is trapped between the tube and the tire. As the tire slowly lets the air out, the pressure goes down, even though there is no leak in the tube. I just pumped it up again. What say you?
· Adorable Furry Hombre
Losing 50% of pressure over 24 hours is not a slow leak. And yes, there is a leak in the tube. Remove the tube, and inflate it in a bathtub. You'll see a stream of bubbles.
Yeah, I guess that was pretty dumb thinking. Even though the tire is sealed against the rim, and the spoke holes are taped, air will still go freely past the valve stem. It's frustrating though with a new tire and new, high end tube that I did not use levers to mount.
· a real member's member
remove the tube, and inflate it in a bathtub. You'll see a stream of bubbles.
takes too long and uses too much water. inflate it until it starts to deform, then submerge sections of the tube in the bathroom sink to identify the leak(s).
1 - 9 of 9 Posts
