1 - 12 of 12 Posts
I’ve got a Neuvation wheel missing 1 NDS spoke due to a broken flange. Otherwise in good condition. (A stronger rider than me popped it on a climb.)
If it is reasonably true, would it be dumb to use this as a trainer wheel for the winter? I don’t think there’s any reason why I shouldn’t give it a shot, but any additional input is appreciated.
Why not? It's not like you're gonna suffer a terrible crash if the wheel tacos on the trainer.
flanges should out last spokes, you should be able to wuarentee ,even if you are not the original owner.If it tacos the quarentee might be shot, or you can say it did it on the road and "lucky,i escaped serious injury"
wheelbuilder
A further failure could send a spoke whipping around, hitting your frame. That's about the worst that could happen. I like the finish on my bike too much to do that. You could a real cheap, used wheel on ebay to serve the same purpose. Check around a few shops and someone might be throwing away a wheel that would be fine.
-Eric
I fail to understand all this concern about having a "trainer wheel" or special tires for a trainer. I use whatever wheel/tire is on my bike for trainer rides. Granted, I don't keep my carbon tubulars on the bike all the time so I don't use those but anything else has always been OK for me.
That said, I wouldn't use a wheel with a broken spoke flange any longer than it took me to ride it home, take it off my bike, and replace with another wheel. However, its your bike, your trainer, so do what you feel is best.
Ya, what ATP said...!
I'd email Neuvation. A guy I commute with had this same problem (broken flange) after about 3 years of ownership. He was able to send his wheel back in exchange for a returned wheel that was used but in better condition than his at no charge (with the exception of one way shipping). Nothing to loose and this would be a major win considering the wheel is probably out of warrantee.
To your question, yes, ride it on the trainer... why not. I wouldn't trust it on the road but everyone evaluates risk differently.
Oh..I guess I misread - I thought you were going to use it as a training wheel on the road in the winter. Not ON a trainer. Still, I just don't think it's a good idea, but not nearly as bad as idea as riding it on the road.
Premium Member
How much do you use your trainer?
I do not too regularly, but when I do, after only a few hours, the rear tire becomes a melted mess.
I have a wheel with a worn brake surface, and a worn out cassette that the common gears I use skip on, and an old tire in the basement. Why use up perfectly good stuff?
1 - 12 of 12 Posts
