1 - 6 of 6 Posts
So I'm building a retro sort of wheelset with 36-spoke silver Campy hubs and Ambrosio aluminum box rims. Thinking 2.0/1.5/2.0 spokes will be OK for my 175 lbs. but my questions are 1) 3-cross or 4-cross lacing? and 2) 2/1.8/2 spokes for the rear drive side?
I would probably go 3-cross with 2.0/1.8/2.0 spokes on the rear drive side.
Do you know the flange diameter of the rear hub?
Any quality spoke will do fine in the strength department. Jobst Brandt reports 100K miles on 1.8/1.6mm spokes. I'm at 14 years and two rim swaps on each wheel due to crash/pot-hole damage on DT 2.0/1.5 front+non-drive side and 2.0/1.8 drive side with weights up to 225 pounds (riding with a back-pack sucks).
Do consider 1.8/1.6mm spokes all around instead - they're more pleasant to work with because they're 30% stiffer torsionally than 1.5mm and the 1.8mm thread imparts less torque than 2.0mm.
3-cross assuming you have low flange hubs.
velojon said:
Thanks. Who makes 1.8/1.6mm spokes? Have only seen DT and Sapim spokes in 2/1.8 and 2/1.5 sizes.
DT, Wheelsmith, etc.
Spokes are sometimes listed by gauge.
Using American wire gauges:
2/1.8mm are 14/15 gauge double-butted
1.8/1.6mm are 15/16 gauge double-butted
2.0/1.5mm are 14/17 gauge double-butted
15/16 source
Though 15/16 are functional spokes and work well (especially in a classic, 32 spoke 3X build) they are not readily available in many locations. QBP does not stock them.
1 - 6 of 6 Posts
