I'm not sure whether to post this here or in mechanics, but here goes.
This is an (I think) an 80-90s vintage Sannino Frame and fork. 700c wheel size. In pretty good shape. My first retro-rebuild, although I rode the things up until about 10 years ago!
Brakes: I have on hand a set of Ultegra Calipers, 6500 series in case that makes a difference. I know they'll work with the brake levers I also have because I used them on another bike together. Will I be able to install these "modern" brakes on this older frame? Any cautions, gotchas or workarounds I'll need to do?
headset I need to buy a new headset. The only thing I'm not certain of is stack height. The frame's head tube is 5 1/8 inches (call it 130 mm). The fork's steer tube is 9" (call it 230mm). This leaves a difference of 100 mm. I'm just wondering how this relates to stack height options I can or should look at. Evidently the original campy headset is 36.3 stack height. I'm just not sure how this works for stack height sizing. Can a 40-42mm stack height headset work? How do you use the difference between the steer tube and head tube lengths to ascertain minimums or maximum stack height for headsets that can be used?
Finally seat tube. It is 27.2 i.d. Does this tell me anything about the tubeset the frame has? I'm pretty sure it's Columbus, but don't know anything beyond that. In case it matters, the frame and fork are about 5.75 lbs (2.6 kg) in a 54X54 size. This doesn't really matter, but I'm curious and trying to start learning about this stuff.
Thanks for your advice
