1 - 2 of 2 Posts
I'm not at home, so I cannot check my bike.
i have a 2011 Oltre Nero with the Super Record groupset. People might love it, but I still think the Ultegra Di2 gives way better feeling. Do anyone know if it's possible to fit a 11s Di2 setup on the Oltre? The set I have is using a battery in the seatpost.
For a clean conversion from manual to electronic shift you need a frame with internal electronic cable routing. You can still do it with a standard frame but you will have to run cables outside the frame. You might look at SRAM E-Tap which is wireless and doesn't require cables if you can live with the current E-Tap short cage rear derailleur (SRAM says 28t max).
I have an Oltre XR with Di2. It is the electronic frame and I have the Ultegra GS 11spd rear derailleur with 11-32 cassette. Very happy with this configuration.
1 - 2 of 2 Posts
