This is pretty trashy. I’m not sure if it was an attempt to make an actual functional guitar or some kind of display piece. The metal work is bad, but I can fix that (remind me to post a picture of the Mjolnir my son and I made out of 1/8” flat steel). There are issues with the scale length and the fret placement, and there appears to be a failed attempt to relocate the frets. And they also apparently used an entire package of epoxy to glue the neck on, and it appears they fashioned the nut entirely from the same material. I think I’ll just saw the neck off and toss it. At the very least I’ll have to mess with the frets again, because if you look at the frets up past the 5th, the spacing is all over the place. I may have to modify the body to fit a neck because there isn’t much room for changing the scale length by moving the biscuit.
I dunno, I suppose I’ll spend Gretsch money and get something that plays as well as a First Act 🤣
I bought this on Shop Goodwill, I suppose I can buy a broken guitar for parts.
