1 - 3 of 3 Posts
So posted this in the SS forum but no hits. People here probably could help better.
I recently got a raleigh record that i converted into a single speed (using spacers o\on a freehub) that i am now going to go fixie. The one probelm though is the cranks at the moment feel like there braking (lots of noises coming from the cranks). I want to upgrade to cotterless cranks anyways, and reading up on the ways to do this i think i'm going the un72/phil rout. I know on Shelden's web site he mentions alot about raleigh 3 speeds, but i wanted to make sure this works on the record before dropping the money on the super expensive cups.
So does the UN72/phil rings work on this bike? I already have the bottom braket but just want to double check before spending $40 on cups (especially if i try it and find it doesn't work).
On another note two, do you NEED to but philwood tools. I know for instance on a campy cassete that was supposed to take only a certain campy BB tool, a different one worked as well (Park FR-1 worked in addition to Park BBT-5). Is there any way to spending more money on phil tools as well? Thanks for and answers.
Arrogant roadie.....
Old Raleighs with cottered cranks often used Whitworth threading, which is incompatible with modern bottom brackets. I doubt that you will find a whitwort-threaded UN72 cup. If you do, it won't be cheap. In fact, anything that will fit these threads won't be cheap.
Before you jump ahead, I would suggest that you check the old Sheldon site about the 2 major modern types of BB's, and the 3 obsolete types (as well as the Ashtabula-type cranks) before doing anything.
Thats just the thing, Sheldon's website said you can use a UN72 with phil woods 26tpi cups and it will work, but i just wanted to make sure it would work on this bike before droping 60 bucks.
1 - 3 of 3 Posts
