1 - 5 of 5 Posts
Carbon Fiber = Explode!
Has anyone put tires bigger than the recommended 700c x 28 that Mavic says is the maximum for the rim?
If so, what's the biggest you've put on. I really want to get a set of 38's but I'm not sure if they'll stay on, or... even if it's safe.
p != b
Plenty of folks run them for cx, with correspondingly fat tires. I've run Michelin Mud2 32's (measure about 35mm across) without any real trouble. (Obviously, bigger tires with lower pressure increase your chances of pinch flats, but @ 200lbs, 45 psi in the muds seemed pretty safe.
(not to mention that in the early days of 29ers, some folks used OPs with much larger MTB tires...)
Studded tires... here we come!!!
1 - 5 of 5 Posts
