1 - 7 of 7 Posts
Not too much I can find about this online, though a little. I'd like to clarify if it's a bad idea or not based on risk and experiences of others.
The reason I'm considering wired over folding and ordering online is because of limited expendable income and a good deal on Ribble; of course that good deal being dependent upon the tire not being damaged.
I never worked in a LBS and perhaps they get some tires in larger containers in larger orders so I'm not sure how that works.
The one wire beaded tire I ordered online from a non local small shop was not folded and put in a fairly sealed thick brown paper bag though had more of a slight physical deformity, but it was indeed small and caused no discernible issues. :smile5:
I am tempted on a deal on Ribble Cycles online on some wire beaded tires, thus my question.
So again, what are your experiences with this? Any experiences specifically doing this with Ribble?
Thank you!
I love to climb!
You'll be fine. Usually we get wire bead tires in a large box from our distributors, but every once in a while they'll come twisted, then folded over so they can use a smaller box. Never actually had an issue.
Ribble is fine but I wouldn't deal with a UK site on a cheap item just to save a few bucks. Tracking and receiving can be an adventure (though no fault of Ribble) and returning is expensive on the off chance you do get a bum item. There's also a chance you get dinged with a surprise import tax.
Off course that doesn't apply if you live in the UK.
Check out nasbar.com.
I buy all my tires on line. No problem with wire beaded. Agree with the previous comment about buying stateside -- assuming that's where you are -- rather than trying to save a few bucks on inexpensive tires. Beside Nashbar, which has sales all the time, BikeTiresDirect is a good source.
Thanks for the advice, Jay and mtrac. Did not think about that thoroughly. I may reconsider. At the very least, I will likely inquire to Ribble about the procedure for such a circumstance--I presume you are right and chances are they want one to send an item back if it's compromised to receive a refund or return.
True, I wouldn't worry about it.
1 - 7 of 7 Posts
