1 - 3 of 3 Posts
I am considering a Felt DA frame that I will build up with Campy Record. I can get a pretty good price on the Oval Concepts A921 Integrated Bars....the bars come with an Oval 710 adjustable reverse bolt stem (this set of bars REQUIRES the reverse bolt technology). I am under the impression that the stems that come stock on the DA are made by Oval Concepts, so I just want to be sure I can pop off the stock adjustable stem and throw on the stem that would come with the aerobars (because even though the stock stem may be Oval, it is a normally bolted stem, not reverse). Anyone with any experience with this?
· No team-cest unless 8+!
I had problems installing an Ultegra crank and rear brake-- the one of the bolts on the brake kept hitting the crank.
I don't know for sure, but I would double check somewhere (I'm sure someone has tried installing Record on a DA by now) to make sure that you won't have this problem.
I called Felt about it and they just said "uhh... We know that Dura Ace works..." Yeah. Thanks. :rolleyes:
This was sometime last year.
1 - 3 of 3 Posts
