1 - 6 of 6 Posts
Where is the valve hole on your rim located? I just got Aerohead rims and on my rear OC rim the hole off-center. I didn't notice this until I got home. Are yours like this as well? If not, is this something I should be concerned about?
Thanks
wheelbuilder
Thanks
The hole should be in the middle of the rim, not at the deepest part of the v section. Since it is offset, it looks like the hole is in the wrong spot.
-Eric
I'm confused. Wouldn't the deepest part of the V be the center? The hole is not at this point but just inside of it on the drive side. On the front rim, which is not OC, the hole is centered.
1 - 6 of 6 Posts
