1 - 9 of 9 Posts
Question Pasela users
That is a good deal. I have some 700x28 TG's that are a few years old and measure closer to 25mm. Does Panaracer still over-state their widths? Would the 700x32 be closer to 28-29mm?
· Banned
Last set of 32s I bought measured 32 on the nose.
· What'd I do?
The stated width is usually close. However, they are often taller than you think they should be. If you have ever had any clearance issues, get the size smaller than you would otherwise (That means if you have Dura-Ace calipers, for example, and the corresponding racing frame, they probably won't fit.)
· Banned
+1 on the height- I had to cut down the bolt under my fork crown that holds the fender in place to fit the 32s...
1 - 9 of 9 Posts
