Park Tool has announced four new tools for Spring 2021. With bicycle mechanics having to work on an increased number of bikes each day, these new tools help to save time by making tools more convenient and easier to use. These products have been made available to Park Tool’s worldwide network of authorized distributors and should be available for purchase from your favorite retailer in the coming weeks.
Related: Stock up on tools and repair essentials at Jenson USA - Save up to 40%
Park Tool DAG-3 Derailleur Hanger Alignment Gauge
DAG-3 Derailleur Hanger Alignment Gauge An alignment gauge is essential for diagnosing and repairing bent or misaligned derailleur hangers, often the source of shifting problems. The DAG-3 features an all-new design, engineered, and built to be light, accurate and versatile. The sliding indicator can measure derailleur hanger alignment against bicycle rims of any size and rotates out of the way to clear seat stays, racks, and other obstacles, allowing 360-degree measurement. The long, precision-extruded aluminum body is built to exacting tolerances and provides ample leverage for making adjustments.
The HBH-3 securely holds handlebars in place on any bike in any position while in a repair stand. Useful for brake bleeding, cable and housing routing, lever adjustment, or any scenario where you want to prevent the handlebars from rotating, including storage or working with the bike rotated upwards. With its articulating clamps and adjustable straps, the HBH-3 can easily be attached in a wide variety of positions onto almost any handlebar, seatpost, frame, fork, or repair stand. Anodized aluminum construction with soft rubber straps.
The QTH-1 is an ergonomic T-handled bit driver equipped with eight common bits to fit a wide variety of fasteners and fittings found on bicycles. The magnetic “quick-change" handle allows for onehanded operation and makes changing bits quick and easy. The bit holder can be magnetically attached to any magnetic surface such as a repair stand or toolbox, or can be permanently mounted to any wall or tool board. The QTH-1 is a professional-grade tool built to withstand the rigors of daily shop use and is fully rebuildable.
The 2197 is an add-on accessory for the Park Tool DT-5 and DT-5.2 Disc Brake Mount Facing Set to enable easier and more efficient facing of disc brake mounts on carbon fiber frames. Features a brazed-on diamond grit surface that is over 100 times more durable and effective on carbon fiber than the cutter included with the DT-5.2. The 2197 sits between the cutter of the DT-5.2 and the brake mount, and smoothly and evenly grinds the mounting surface until it is flat and properly perpendicular to the rotor.
- Compatible with 16" to 29"+ wheels (ISO/ETRTO rim sizes from 317 to 630+).
- Replaceable M10 threaded tip.
- Low-profile head fits low clearance thru-axle derailleur hangers and Shimano® Direct Mount hangers
- Length: 16.5” (420mm)
- Weight: 22.75 oz. (645g)
- MSRP: $116.95
- Straps install onto any round tube from 12mm to 60mm (0.5" to 2.4"), as well as most irregular and aero-shaped tubing found on bicycles
- Rotating articulating clamps allow for secure installation onto virtually any bicycle in a wide range of positions
- Usable extension length of 18” to 32” (45cm to 81cm)
- Collapses and folds to 17” (43cm) for storage
- MSRP $42.95
- 2mm, 2.5mm, 3mm, 4mm, 5mm & 6mm hex
- T25 Torx®-compatible
- #2 Philips cross tip
- Bit holder includes empty spaces for 2 extra bits
- MSRP $56.95
