nice!
yer gonna need cables
and bottle cages
and not quite so many handlebars.
/ edit - ok I see cables, never mind.
and bottle cages
You'll need one more seatpost if you intend to match the handlebar quantity, and some more bar tape.Creakyknees said:nice!
and bottle cages
I was wondering if anyone would notice the proliferation of handlebars. Truth is like I said I have never ridden a drop bar bike but I have read up on the terms "reach" and "drop", so what I did was I hunted for some inexpensive bars with a wide spread of reach and drop. My intent is to try out each one to determine which one fits best prior to the final wrap.HIMEHEEM said:You'll need one more seatpost if you intend to match the handlebar quantity, and some more bar tape.
/it'll be a beauty, post completed pics.
Argentius said:SRAM makes cranks, too, y'know.
Amfoto1 said:Looks good... and fun!
This is certainly not criticism, just some ideas to consider...
I use both types of cranks and don't see much difference. They both just need to be checked and re-torqued every so often.
That's a very shallow drop set of handlebars. Probably good ones to experiment with, while starting out on drop bars. Not too aggressive. You've got the bars really high, too, between the bike's tall head tube, the spacers and the "erect" stem orientation. Also good to start with, but you might gradually lower things and see how it feels.
Have you ridden the bike without the Tri bars? I like the "tuck" they encourage, but always felt the bike was a bit "nose-heavy" with them. I've gone back and forth using them over the years, for my typical recreational riding.
Are you using the stock Sram brake pads that came with the calipers? IMO, they aren't bad, but Kool Stop are better.
It's a different fork because the other fork scared me. I had the bike assembled, and I had assembled the fork per instructions (the fork had a carbon steerer with sleeve/nut insert that had to be epoxied into the steerer). At the end of the first ride I hit a hole in the pavement (not huge, didn't pinch the tube or do any damage) when I hit it I heard a "BANG" from the front end of the bike. The noise was pretty loud. I stopped and did a cursory inspection and saw nothing out of the ordinary. When I got back to the house I did a more detailed inspection and still didn't see anything, so I picked the bike up about a foot off the ground and propelled it down onto the concrete. "BANG". I did the same thing two more times with the same result. (I wasn't slamming it on the ground but it was more than 32 ft/sec/sec). Again I inspected and this time I saw a fine dust on the top of the fork crown. I pulled the fork and looked at it and didn't see anything but I was spooked so I bought a new fork with an aluminum steerer and hung the other fork in the garage.FatTireFred said:different fork?
and I hope you closed the brake qr
