1 - 14 of 14 Posts
I'm getting ready to move and will probably need to change the gearing on my bikes to accommodate the new terrain (well, I don't HAVE to, but it will be a heck of a lot more pleasant if I do).
Right now I'm runnnig 11-23 (10 speed) in the rear and 39-53 (double) up front. I ride 2,000-3,000 miles per year and the area where I currently live (Bridgewater, MA) is pretty flat, some hills, but not too bad. This gearing works great for most of my rides here. I'm moving to an area (Acton/Stow/Littleton, MA) which is much hillier, I've done one ride out there and was definitely wishing I had slightly lower gearing. I also do the occasional ride up in VT and my current gearing makes those climbs pretty miserable.
I'm debating between just going to 12-25 in the rear, OR going with compact cranks up front. Which would you reccomend?
Thanks for your comments.
Premium Member
Wait till you get there then ask at the Local Bike Shop.
Either that or just get a fixed gear bike and don't worry about it.
why not...
...switch to a triple? I've ridden both and the triple comes in very handy when I visit my retired parents in TN. Sure I never use the granny in IL but I also never have to swap parts for travel. Mike
cassette
Considering that a new cassette (Shimano) costs about $45 and takes about 10 minutes to replace, that would be the common sense approach. Try a 12-25 or 12-27. If that doesn't do the trick, then start considering more expensive options.
Good idea on checking with the local shop, I'll ask around.
I'm definitely leaning towards the cassette (not a huge bargain since I've got Campy, but definitely a lot cheaper than going compact), it's not like I'm living in the mountains, and I have done some nasty climbs in VT in 39-23 (wishing I had a lower gear with every agonizing turn of the crank).
Not ready to go single speed just yet. I ride in one gear for the whole ride sometimes where I am today (usually about 39-17 I think), but don't think I could handle much larger hills in that...of course it would eventually lead to much stronger legs. Maybe I'll build up a single speed after upgrading my old Bianchi from 7 speed and getting a mountain bike for the stable.
New thinking
So, have you EVER actually needed the 11t cog for anything but pedalling slowly down a hill? With Campy, you can get the 13-26 or 13-29 cassette, learn to spin, and coast in a tight tuck, and unless you do a lot of downhill sprints, never miss either the 11 or the 12. 110 rpm in a 53/13 is about 35 mph, at which point you can go just as fast while coasting. It is a rare situation where someone who needs a 12 t cog (nearly 38 mph at 110 rpm) needs lower than a 39/26.
I would've doubted you two months ago, but I wanted to set up one of my bikes with a lower gear (as cheaply as possible) for some mountainous centuries this year. Thought about a compact, but that gets expensive because you're probably buying a new BB and front derailleur in addition to the crankset. Or if you keep it all Campy (in my case Record) you have to mortgage the house to get a compact crankset (although it will work with the existing double BB). I went from an 11-23 to a 13-29, which required a mid-cage rear derailleur. You can buy just the derailleur cages from Branford Bike for about $50 and rebuild the old one to a mid-cage. You can use a Centaur or Veloce cassette for less than $100. Throw in a new chain, and for $200 you'll have 36"-109" which is the same gearing as a 12-25 with a 34-50 compact.
And indeed, I haven't missed the 11 or 12 any!!
I'm a fan of low gearing and spinning- it works for me. But where I live we have multi-mile climbs. There's a common summit-and-back ride that's done on summer weekday evenings. I'll typically be one of the first to the top, where we regroup and descend the way we came. I often get dropped in my 52-13 on my triple. It sucks to school your buddies on the climb and get dropped on the descent.
I'm also a believer that 11 and 12 in the back is not a good idea (irregardless of what you're running up front). Yes there are exceptions to the rule but for 99.5% of us no need.
"It's alive!"
My old stomping grounds. I've logged ~10K miles in and around the area you're talking about. The hills around there really aren't that bad. The steep ones are short. Back in my racing days, I did it all on a 42/52X12-21.
If you do head for Manadnock (spelling?) or the Greens or the Whites, that's a different story, but if 99% of your riding is going to be in and around the Metro-West area, and you are in decent shape, a 39X25 should be plenty for you. A 39X27 would be even plusher. In either case, it would be a relatively inexpensive experiment for you to undertake. You could set up either a 12-25 or a 12-27 and ride the heck out of it. 6 months from now, if you felt like you needed a easier gear, you could make the change.
But I don't think that would be necessary.
Yours,
Forbes B-Black
Former Shop Manager, Lincoln Guide Service, Lincoln, MA (R.I.P.)
Squirrel Hunter
Centaur or Veloce
Kerry Irons said:
...With Campy, you can get the 13-26 or 13-29 cassette...
Buy the Centaur or Veloce level cassettes and save a boat load of money too. In addition they are loose cogs so if you wanted to get really creative you could mix and match and get yourself an 11-26 although it would take a lot for me to give up a 16t and 18t cog just to have a rarely used 11t cog.
Discussion Starter · #13 ·
Yours,
Forbes B-Black
Thanks, I'll be starting with the 12-25, and see how that goes...should be fine.
Since you're familiar with the area, can you reccomend a good bike shop and/or group to get together with for fast paced recreational rides?
I'd go Veloce and buy a 12-25 and a 13-26 for the cost of one Chorus cassette. The extra grams aren't noticable, and as Kerry said, with the loose cogs you can make your own 12-26 if you want.
11speed.com has Veloce cassettes for something like $45!
1 - 14 of 14 Posts
