This question has been asked before. Here's a thread on it right here on RBR:
Alternative common glue for tubular tires?
In the above thread, there was good endorsement from a few members for 3M Fast Tack Trim Adhesive.
Howevever, today I'm reporting another possible alternative.
It's call DAP Weldwood Contact Cement. Take a look at some pics of using this stuff
As you can see from the pics, the color of the glue is amber similar to the color of Vittoria Mastik One, except the Weldwood glue is a little lighter. The Weldwood glue is also a tad less viscous than the Vittoria, but the important thing is that the texture and tackiness of both glues are similar once they are allowed to dry to a glaze. I think the less vicsous Weldwood is easier to apply than the Vittoria since less viscous allows for a more even application of the glue.
So I took a chance to tried it out on a tubular tire. Thinking that this glue may be "more permanent" than the Vittoria, I only used one medium layer of it on the rim, and one medium layer of it on the tire. To my pleasant surprise, it seemed to work pretty well. My carbon rim has not been dissolved by the glue. The tire was on tight but can still be removed by hand on the road. The sidewall was held in place just like Vittoria Mastik would.
Basically, with the Vittoria Mastik, I would use 2 thin layers of glue on the rim, 1 thin layer on the tire. And this will get me a good bond. However, if I use 2 thick layers of Vittoria on the rim and 1 thick layer on the tire, then this makes it MUCH harder to remove the tire (but the base tape will still be intact with the tire though, i.e., it won't rip away from the tire).
With the Weldwood, 1 medium layer on each surface is just about perfect, and still easier to remove compared to 2 thick layers of Vittoria on the rim plus 1 thick layer on the tire.
The base chemical ingredients of Vittoria is listed as "natural rubber" with hexane as the solvent. And contains no toulene (which is a solvent). The base chemical of the Weldwood is latex in toulene solvent. I believe toluene has been banned in some states. Toluene and hexane are organic solvents. I'm no PhD, but that's pretty damn close enough for bicycle works for me.
Now I'm not sure what "natural rubber" means on the Vittoria, but it sounds like latex to me. Afterall, these types of glue are basically latex based glue dissolved in an organic solvent (hexane, toulene), and it's the latex that is the "gluing agent" after the solvent has evaporated away (in about 10 minutes the glue will dry to a semi-wet glaze). The tackiness of the Weldwood and Vittoria is very similar feel to the hand after their respective base solvents have evaporated.
2x 3oz bottles of Weldwood almost equal one 250g can of Vittoria.
Cost of 2 cans of Weldwood is less than $10. Cost of 1 can of Vit is about $25
Anyway, just thought I have a preliminary report on this experiment. So far, it does look promising substitute. And it's also the cheapest possible substitute I've found. I understand safety and getting the right tool for the job is important, so if you ain't comfortable, don't use.
BTW, I have also use the Weldwood for patching clinchers tubes with great success as it's stronger than than typical rubber cement you find with any ole patch kit. So it can definitely be used as patch glue substitute.
