Here I go postin' OT again. Crazy coloured alu hoops on da Nago!! Looks fantastic. What rims are those? 30mm?jd3 said:All my bikes have short stems.
They are Velocity Deep V'sschimanski said:Here I go postin' OT again. Crazy coloured alu hoops on da Nago!! Looks fantastic. What rims are those? 30mm?
aceholesaintsfan342000 said:Also known as "The chode thread"
Yes, I have a Ritchey WCS 90 mm carbon stem, on a Litespeed Tuscany 61 cm (still have between 4 - 5" of seat to bar drop), and my Garmin 305 is mounted on it (sorry, no pic at the moment). Might depend on the actual stem, however, for it to fit -- never know if the bar mount (on the stem) will get in the way or not, as not all stems are created equal123prs said:Can a Garmin 305 Edge be mounted on top of a 90mm stem?
Just went out in garage and stuck the Garmin on my bike, with the 90 mm Ritchey WCS carbon stem. The little mountng bracket and rubber block under it results in the 305 mounting over the front of the stem, the front of the Edge is actually over the portion of the stem that mounts the handlebars, the front of the Edge being about even with the front of the stem. The back of the Edge is about even (though above) the front side of the carbon top cap of the stem. It could probably be slid back (the mounting bracket) on the stem a bit if you wanted to.123prs said:Thanks for the info. I just wanted to make sure it fit. Right now, my Garmin sits on a 110mm stem. I think the Garmin itself is about 90mm long.
Your Colnago...do you know the model and year? It appears to have round tubes so it couldn't be any of the Master varieties that I know of.jd3 said:All my bikes have short stems.
