I believe it's based off of VO2 max levels and their limits.How do people know the theoretical limit is 6 w/kg?
Also, do any of you think nutrition has played a role in improved performance? For example, back in the 80s racers used to eat sandwiches as race food, and cake for recovery...
I agree that it would only be another "obstacle" at best. Sooner or later they would figure out a scheme for manipulating the data. What about software in head units which would keep two sets of records -actual and 10%reduced. All you would have to do is submit the reduced file showing "proof"you were doing the legal limit.Not to mention that the equipment is improving.
One argument I made in another thread is that given the lengths athletes have gone to in order to mask doping, such as microdosing EPO to artificially boost reticulocyte count after transfusions, why wouldn't a savvy cheat just calibrate his SMR to give a lower reading?
Or lie about his weight?
When it comes to equipment at the Pro levels ... all rules are "Strictly" enforced ... heck, last year they were even enforcing the flat TT saddles (i.e. no tilt at all in the saddle). So, yea ... they enforce the weights of the bikes. Many pros use aluminum stems, bars because they are both heavier and stiffer ... and those with bikes below the weight limit end up putting lead weight in their seat posts to bring them up to the minimum levels.Is the minimum weight actually enforced?
And according to the article, at 385FTP and 140lbs, he's above 6wt/kg!
As it stands, they are never entirely honest with their listed height/weights ... much like the NFL/College Football inflates the size of their players ... Cyclists deflate their size.Or lie about his weight?
Because that's rotating weight that has to be accelerated over and over on a climb ... they actually want the lightest wheels possible and heavier weight in static areas.If the weight limits are enforced why don't riders use deeper wheels on climbing stages?
Wookiebiker gave a pretty good description of the stuff. That said A LOT of what we see supporting claims that the sport is cleaner are estimated watts. Hell all of the stuff you see supporting claims Lemond and his ilk did not dope is estimated.People keep saying power data power data. could someone please explain how a certain power output is indicative of drug cheating? Thanks.
You fail to bring in technology not related to PEDS and more scientific training methods. Actual wattage, speed etc will increase, within limits of course. Also as time moves on the gains will be more and more marginal. Every generation says "we have reached the limit" whether it be the 1920s, 30's and so on. You can look and see this simply in the hunt to break the 4 minute barrier in the mile run. That was once honestly seen as similar to breaking the speed of light.Lots of science and observation. Humans can't run 45 mph, they can't fly, they can't swim 10mph and they can't ride a bike pushing insane wattage numbers for very long. These are the limitations of our human bodies. Over the past 150 years the human physiology has not changed and yet all these records are being broken. What has changed? PED's and their availability.
People have already broken it down for you.. But anywhere over 6 w/kg becomes suspect because this is the limitation of the human body.
Thankfully that means the peloton is slow enough that you can have a useful (if not world conquering) career clean. By all accounts a sprinter can win with w/kg around 5.0 and a domestique can be useful at 5.5, both realistic numbers. Yeah there will always be someone who dopes to the gills to avoid a career as a garbage man, but no longer does an entire generation need to dope just to stay racing in Europe. Hopefully a tighter net eventually catches the Ricco's who flagrantly break the rules and the teams no longer encourage riders to take everything under the sun. Hopefully.The biggest difference is the riders can't go crazy with their doping and have to be more subtle about it than in the past. It's still all about recovery and build cycles ... the build is important for the one day races and the build/recovery for the stage races. They micro dose EPO now instead of using larger doses, use lower levels of HGH and have developed new drugs that might be slightly less effective, but are undetectable.
No, it's not.People have already broken it down for you.. But anywhere over 6 w/kg becomes suspect because this is the limitation of the human body.
Mind if I ask who/when this was?4. the best threshold power measured for as far as we can tell a non-doped athlete was 6.4W/kg
Not at all, but it's not my data to reveal.Mind if I ask who/when this was?
Boardman was estimated at 6.4. Whether out not he was clean or this is who Alex was talking about...Mind if I ask who/when this was?
