1 - 3 of 3 Posts
Last night during a training ride I discovered my rear wheel no longer wanted to freewheel. When I stopped pedaling, the chain would pull on the RD and the freehub wouldn't budge. I took the freehub off tonight and found the culprit. Turns out the spring around the three pawls somehow migrated so the opening in the spring was directly over a pawl, causing to to malfunction. Upon further examination, it appears there was supposed to be some kind of block in a detent on the hub body to prevent this, but it is conspicuously missing. Probably ground up into dust or something.
Am I right in assuming it's toast, and that I should replace it? I moved the spring around so the opening was between the pawls, however I'm concerned it will migrate back over time. It functions as it should now, but what I'm concerned is for how long.
Discussion Starter · #2 ·
As an update, the freehub was replaced by Saris through my shop as a warrantee issue. I decided I didn't want to even mess with it, so I took it in, and now I'm happy as could be.
Thank you Saris.
Just wanted to follow up to let you know you are not alone. My "Indent" in the freehub body is missing. Symptoms were first intermittent non-free wheeling, then complete non freewheeling.
I am away from home and I have a race on Sunday. A bit concerned about replacement... I'll give them a call tomorrow AM.
1 - 3 of 3 Posts
