1 - 5 of 5 Posts
Ok so here's my first post.
I am moving to SF from LA next week and losing the car for a bike.
I been crashing on my friends couch between the move and enjoying riding his Eddy Merckx around and decided I want a road bike.
I have been scouring Craigslist from work pretty much constantly, but have decided to resist the urge for instant gratification and wait till I check out LBS in SF.
My gf obtained a Giant Yukon from her workplace for me. This is not the bike I desire but will treat it well until I get another.
This bike has not been ridden/touched/maintained in a few years.
The gf put some fancy road tires on it but I am ready to give this bike a full overhaul.
I plan on replacing the cables(maybe?) and handlebar grips(definitely).
I want to remove and fully clean just about every component but not replace anything if I don't have to.
What else should I concentrate on to get this bike back in shape?
This is from my father I guess, who never let me take a car to a mechanic even when we had to change headgaskets.
Is replacing anything on this bike even worth it? :skep:
I know this is roadbikereview, but you guys surely know something and I will join the roadbike cadre soon enough hopefully!
I think this overhaul is worth my time as a learning experience.
Maybe I'm just bored at work and want to talk! Gimme advice!
Replacing parts that are still working is not "worth it".
Get a book like Zinn and the Art of Road Bike Maintenance. Read through it and when you find something that interests you, give it a try. A headset overhall is pretty easy and fun, and helps you understand how the frame and fork work together. Replacing cables is pretty easy too, and worthwhile, but you should buy a good cable cutter. You'll probably need to accumulate other tools as you do other jobs. Always use a good-quality tool that is designed for the job.
G
You'll be fine. There's a lot of wrench heads in these forums who will make working on your bike sounds worse or harder than it is. Just remember that your working with steel/aluminum/carbon/ti products which you won't break. At worst you'll have to swing by your lbs for some fine tuning after you put everything back together. I do most of my own repairs and adjustments on my bike. Self taught by trial and error.
Cool thanks for the input guys!
I was looking at the park tools and see that they are kinda pricy.
I am assuming most tools are not bike specific, but what are some of the specialized ones that are definitely worth the money to have on hand? like, I never bought a "piston depressor" or whatever kinda instrument to reset a brake piston, but a c-clamp does just fine.
Cone wrenches, cassette remover to start
1 - 5 of 5 Posts
