1 - 12 of 12 Posts
Obviously can't give you a guarantee that the rim is OK; ride at your own risk.
BUT, I've drilled rims for schrader with absolutely no issue.
Sent using Tapatalk
if you're running schrader, no problem. If you're running presta, you can get adapters\shims to fill the void left by the smaller diameter valve stem, no problem.
Continental supplies a stepped nut with its presta valve tubes. I believe the stepped part of the nut fits in a schrader size hole and will keep the valve stem centered.
Cpark
I agree, I have done this a couple of times in this situation. It works well for me.
Banned Sock Puppet
If this rim was designed to be used with Presta, it was probably for a reason.
This is mostly a safety issue. Remember that any hole drilled into a rim takes material away from it and will make that point weaker. I certainly wouldn't recommend using a 15mm (internal width) rim that this was done to. There are plenty of 19mm rims that use Schraeder. Yours is 17mm. I would get the advice of a reputable bike shop before riding these.
*Assuming* they were drilled properly, at your weight, I personally think they are fine.
Again standard disclaimer - no guarantee, ride at your own risk, yada yada.
Sent using Tapatalk
Banned Sock Puppet
Sent using Tapatalk
Do you love your mother? Would you put her on those wheels? :)
1 - 12 of 12 Posts
