Came across this warning at the ITM website:
"WARNING: READ
CAREFULLY READ THE FOLLOWING INSTRUCTIONS SUPPLEMENT REGARDING THE CORRECT ASSEMBLY AND USE OF YOUR ITM "THE STEM"
Your ITM “The Stem” is a hi-tech product and must therefore be assembled and used with the greatest care.
Your ITM “The Stem” must be assembled only by a specialized mechanic using the appropriate torque wrench.
ITM urges you to take your bicycle immediately to your expert mechanic and not to attempt to perform the following operations yourself.
If you are unwilling to comply with our request, following these instructions carefully and remember that you are assembling your ITM “The Stem” entirely at your own risk and peril and that ITM cannot and shall not be held responsible for any damage you may suffer from failure to fully comply with the following instructions.
MOUNTING THE HANDLEBAR BEND ON "THE STEM"
• Your ITM “The Stem” must be mounted no more than 3 to 4 mm (0,12 to 0,16) from the top of the steerer.
• Your ITM “The Stem” has been designed to be fitted onto a fork steerer that is 25,4 mm (1” in) in diameter by means of the reduction bush supplied by ITM. If you do not have an ITM reduction bush ask your mechanic for one immediately or call us on tool-free number 800 320 220 if you are in Italy or send us an e-mail at [email protected] and we will send you one directly from the factory.
•If the diameter of your fork steerer is 28,6 mm (1” 1/8 in), and is in carbon, it must be fitted to an“expander” that will prevent it from being crushed at the entire height of the stem clamp.
Also regularly check the carbon steerer for damage. Consult your mechanic and ask for an “expander” that is suitable for your fork stereer.
• “The Stem” must never be assembled reverse (see Fig. 2).
NOTES FOR YOUR SAFETY
• “The Stem” that you have purchased has been designed and manufactured for use on a road racing bicycle. Any other use is absolutely forbidden.
• Maintaining the efficiency of “The Stem” you have purchased.
Like all other ITM products, “The Stem” you have bought has been manufactured using carefully chosen materials that guarantee perfect quality and reliability. In confirmation of this fact, “The Stem” has passed some of the severest tests in the world, including that required for ISO 10395 and NFR 30-020 approval.
• “The Stem” is a handlebar stem mainly for professional use. Given that ITM considers the complete safety of its customers as fundamental, we advise you to take care that the correct functioning of “The Stem” is not compromised by prolonged use or in conditions of constant, heavy stress. Check the condition and wear and tear of the stem periodically, and do not hesitate to replace it if it has been mounted for a number of years and has been much used.
• Before every use, it is advisable to check every component of your bicycle carefully, including “The Stem”. Check in particular that “The Stem” and your ITM handlebar bend do not display any cracks, folds, deformations or changes to the original setting. If they do, do not use your bicycle, but take it to a reliable mechanic for repairs or spare parts, as required.
• If it should be necessary to replace the bolts, only original ITM bolts should be used.
• Check the torque setting of the screws regularly using the appropriate torque wrench; torque to be applied on stem bolts; 6 Newton per meter. If you notice that screws continue to loosen it means that the steerer is suffering from fatigue and is collapsing. If this is the case, do not use your bicycle but take it to your mechanic for a thorough check.
• At the end of each ride, check the stem for damage and then check for any pits or cracks. The area of the rear clamp is the most subject to stress.
http://www.itm.it/sito_uk/main_uk.htm
Now, are all those precautions even POSSIBLE?
On the one hand, they say the product is fantastic: "carefully chosen materials that guarantee perfect quality and reliability," then give lots of warnings that essentially say that if your installation and maintenance are not PERFECT, then the product can fail. HUH?
Isn' this a bit contradictory? "The Stem” is a handlebar stem mainly for professional use. Given that ITM considers the complete safety of its customers as fundamental, we advise you to take care that the correct functioning of “The Stem” is not compromised by prolonged use or in conditions of constant, heavy stress."
I think you'd need a full time inspector using an x-ray device to adequately check for cracks as suggested. Do we want any products that require that level of scrutiny, or is this simply over-reaction to getting sued over failed products?
My view is that if something is that scarey, requiring that level of warnings, then don't even make it. Make something reliable and trustworthy.
Thoughts?
"WARNING: READ
Thoughts?
