While saving up for a frame that truly fits my size, I'd like to make some adjustments to my 55 cm frame to better fit my body type.
I'm 5 ft 10.5 inches tall and my inseam is 33.625. From the proportions I've learned, my ideal frame size should be 57cm.
I have a 55 cm Trek 2100 composite frame. I've adjusted the seat height and the seat forward/backward measurements using a plum line (from foward knee to pedal) as my gauge. So my saddle is now correctly adjusted, I hope. The issue now is that since my seat has been raised, my bars are sitting a bit too low and too close to my core.
Is there a way to lift a 1" threadless headset and extend the stem to better fit my body type on my seemingly too-small-for-my-size frame? From what I've read thus far, it seems that most of these options are better found for a 1-1/8" headset...
Thanks for any thoughts/direction...
