Hello everyone.
I have a question with tubeless tires. They are my first tubeless set so I don't have enough experience, if it is normal or not.
Information about me;
I am riding on a Tarmac with Ultegra set. Ultegra 6700 wheels and Hutchinson Fusion 2 tires. I weight around 65kg and bike is around 9 with water and everything.
I am riding on 80PSI in the front and 90 on the rear. I don't have sealant on the front tire (but I had the same problem while I had)
My problem is;
While I am passing some bumps and holes on the tarmac, usually with a sharp edge, I am hearing the air is leaking from the tire, like "psssss" sound. Also it happened on the cobbles several times too.
I believe that the bead is releasing for a second from the rim, and there is a little air leak, and they hold again. Or it is just the air sound when they have hit from outside.
The question is;
Is that sound normal with tubeless tires? Should I be worried about sharp cornering or anything else?
My problem is;
The question is;
